Exhebio novice
Hi…I’m new to software …sorry for being thick!
Can anyone guide me to adding an Exhebio file to my site please. Best way for best results, I draw graphic box and action insert exhebio file…but it previews huge and not in position?
Can anyone give me a step by step way of doing this…and showcase!
Thank you.
Hi Darren,
Have you seen the knowledge base articles about working with Exhibeo and Showcase yet? If not, I’d recommend starting there. Here the are links:
Exhibeo - http://www.softpress.com/kb/questions/315/
Showcase - http://www.softpress.com/kb/questions/316/
This one is a bit long because it also explains working with the application, but if you search for "Showcase Action Reference Section” that will get you to the part about using the action in Freeway.
Hope this helps,
Katie Wagner
Technical Support Operative
Softpress Systems Ltd
Thank you.
Ok will check…thank you
Sent from my iPad
On 9 Jul 2014, at 22:03, Katie Wagner email@hidden wrote:
Hi Darren,
Hope this helps,
Katie Wagner
Thank you.
