[Express] Contact form problem(s)
I’ve made a second contact form…but it’s not sending results to me (it hasn’t been made public yet, so it’s just me uploading & testing).
It’s also not going to the Thanks page…just recirculates to itself.
What have I done wrong? Unfortunately, I need to get it working by this evening for my friends’ shoot.
http://firerosepapillons.net/2009photoshoot.html
Thank you,
Helen, confused as it is set up like my first form that does work. At least I think it is.
I decided to try copying my first form, and changing some fields and the email addy it goes to.
It works, including bringing up the right Thanks page, but somehow - even though I changed it - wants to go to another address then is forwarded to me.
I don’t know how to correct the email addy thing.
Cheers,
Helen
No form on that page Helen
How are you creating this form and do you have a link that we can check out.
Ah…because I gave it a new name when I copied the first page’s form.
Here you go:
<http://www.firerosepapillons.net/photoshoot2.html
Sorry about that…
Thanks!
Helen
And how are you creating the form - with an action?
Can you explain what you mean by this?
If there is an afternoon break then these times wouldn’t be available would they?
Thanks Dave for pointing out the time problem on the schedule.
The form itself is within a table, and with an action, yes: PHP Feedback Form.
Thank you,
Helen
Yes but can you explain what you mean when you say
Be very careful in the action when you are putting in the recipient address - select all the text in there and delete it before copying in a correct address - I usually copy from a text document where I can easily see whether it is right or not.
The action entry field is just not big enough to let you see everything that is in there and can lead to mistakes.
maybe that is the e-mail address issue. I will work on that.
Thank you for your help!
Cheers,
Helen
While we are there you have 2 - 1st time selections
And shouldn’t your Sat/Sun selections be 1.00 - 3.00 NOT 1.30 - 3.00 as you have on the pickers.
I am my own worst proof-reader…thanks much!
Helen
