hello all,
over the weekend i upgraded to 5.4 express. after i published the site all of my embedded flash was gone. additionally all of the google friend connect widgets were also gone.
has anyone else had a similar experience and if so how did you fix the problem?
i tried simply dragging the swf into the html box but that does not work either…
thanks in advance
jd
