WHY IS THIS HAPPENING?
I can’t move forward until I can design a page that has the correct proportions. Right now, when I preview my design, the background image is larger then it is in Freeway?
HELP!
Not sure if you managed to resolve this. NOt sure if this will help but…
Check your page size when you have set up the file to start with and also check the size of the image you are using on your page. The background is actually set behind the document page and can be resized if you are importing an image as a background image in which case you control the size of the background image by adjusting the proportions in an image editing package. Or you can tile it etc via the Inspector panel for the page.
