[Express] How to shield parts of your Site?
Hello and thanks in advance
I have some subscribers to an online magazine that I create.
I would like these subsctibers to have access to all the older magazines, but I do not want to make them accessible to just anyone. Is there a tutorial available on how to do that?
Is there a way to do this in freeway Express, or do I need to upgrade to professional?
Thank you so much for your time.
Dust
How do the subscribers pay for the back content, and how do you identify them? Those answers will help guide us to a solution. There’s no Action that will keep people out of a folder (such that Pro would be a solution) that I am aware of. This will need to be solved on your server.
Dust
Hi Walter
Thanks for your input.
People pay for the subscription via my webshop, which is another Site. You said:
What do you mean by this? Do you mean that Pro would possibly offer a solution/action?
Greetings
No. Express only allows the Actions that ship with it to run, no third-party Actions can be installed. Pro allows third-party Actions – that’s one of its many charms. But as I run the ActionsForge, and have my finger very well on the pulse of All Things Action, I can tell you with some confidence that there isn’t an Action out there that can do precisely what you describe.
What you need to look into is a membership application which can be installed on your server. Most servers support PHP, so you might want to start here: PHP user authentication / login scripts - Free, commercial and open source scripts
On Jan 30, 2013, at 9:27 AM, Dust wrote:
Hi Walter
Greetings
OK. That sounds good
Thanks Walter.
