You shouldn’t delete anything in your site folder and then upload or synchronize that folder with your server. But you can delete everything in the site folder, publish again (to get a fresh copy of everything you need) and then upload. If Freeway puts a file in your site folder, that’s because it needs that file. Freeway is generally very aggressive about reducing duplication, and won’t give you two identical copies of anything. If they share a name, but have a unique suffix like 1 or 1a, then they are fundamentally different in some way.
On Jan 18, 2013, at 4:06 PM, banditress wrote:
I think this question is related to this thread. When I look at my site folder, I have lots of files that are obviously versions of existing files. Can I delete the extraneous files, and if so, which ones should stay, without messing up my website? I assume that the (filename)a.ext, (filename)b.ext are redundant and can be deleted, but just want to be sure before I do so.
thanks!
