Getting on well with Tutorial 2, but got stuck on page 51 at bottom right of page, on importing ‘header-bar-gif’ graphic, and it says set Horizontal to ‘Center’ and ‘Vertical’ to ‘Top’.
How do I do this, as I cannot see any button, menu or anything to follow this step. Perhaps it’s staring me in the face but I cannot see anyway to do this. Help most appreciated!
I have now solved this. I did not import in the right way.
Haven’t done this tutorial but it sounds like this is being applied as a Background image so that is done through the inspector.
Select the page (or wherever the graphic is going) and look in the inspector for Background settings to choose the bg image and its positioning (under the paintbrush Tab)
Thank you DeltaDave. Problem solved! Help much appreciated.
