[Express] Upload Problems
I’m having problems uploading amended pages to my site. I get this message: “Could not complete the ‘Publish Site’ command because file not found”. The pages look fine when previewed in the browser, but look a real mess after uploading (having ignored the error message).
My OS is Yosemite. Any problems here ?
Anyone got ideas ?
Brian G
www.bjgraham.co.za
So is that it uploaded at http://www.bjgraham.co.za/index.html because it looks complete to me.
Hi David. I’ve just looked again. and still a mess ! The calendar is half 2014 and half 2015 ! Also on the Hoedspruit page the slide show has not updated to show December !
Any ideas anyone ??
Not from where I am looking - its all 2015.
This looks like a Browser cache issue.
Have you tried visiting your site with a Browser that you dont normally use - there are many you could download just for this purpose.
Indeed no problem at all on my four browsers Brian.
2015-01-02 11:21 GMT+01:00 DeltaDave email@hidden:
List Options | FreewayTalk
Hi Guys, thanks for the input. Yes, I checked the site using my wife’s laptop and sure enough it all looks good except the calendar doesn’t rotate beyond January. The Hoedspruit slideshow is also fine.
So I think you’re correct about browser cache. Any idea how one sorts that out ?? however it still could be a Yosemite bug as I’ve had endless problems since upgrading to Yosemite. Or it could be that my Freeway Express needs an upgrade ??
Cheers, Brian.
Again still likely to be a Browser cache issue. Download and try a different one on both machines.
Nothing to do with Yosemite if we can see it fine.
Thanks Dave, I will do as you suggest. So for the moment I will close this thread. Appreciate your input.
Cheers, Brian
