[Express] using white box over background image as a text box?
I have a background image that I want to use, but I want the text body to be in a white field.
I set my background image, placed a rectangle as a White colored html item where i want the main body of text. It seems to work just fine.
Is this the proper way to achieve want i want?
Thanks in advance!!!
By background-image being “set” you mean in the Inspector as the Page Background and then by text body in a white field you mean inside a table item with a white background, then yes, that makes sense to me.
Hi Dan,
Thanks for the reply. Yes on the Page Background in the Inspector, and for the text body I just drew a box after I clicked “Html Items”, so I don’t believe that’s a table. but it appears to work.
