I have a LaCie Ethernet Mini NAS with both ethernet and USB in/outputs. I have retrieved a load of files to it from another disk which died, using File Salvage, which seems to have done it’s job nicely.
On the LaCie there is a folder of 70,000 files and to access it via the ethernet connection takes forever, so I thought I’d try it via the USB 2 connection to see if it was any faster.
I restarted having substituted the relevant cables and it can be seen in the system profiler along with my other externals, but it doesn’t mount on the desktop.
Thanks for the reply paul, but Disk Utility can’t see it, only System
Profiler.
I’ve had similar problems and the only solution that worked for me
was to rebuild the drive with Disk Warrior. For some reason DW was
able to see the drive when nothing else would.
Thanks Todd, but as it mounts fine via the ethernet connection and I
can see everything (albeit slowly with so many files in one folder I
think that the drive is fine.
I’ve tried connecting it with it’s USB and USB2 inputs and both ways
it can be seen in System Profiler but not with Disk Utility.
I’m not very good at knowing what is compatible with what, but it’s
generally mounted as an AFP drive, could this be something to cause a
problem?
Some of these NAS devices are formatted as FAT32 (Windows) in order to be cross-platform. When you access them over the Ethernet, you are actually accessing an embedded file-server running on the drive, as if you installed a server on your network. That server would effectively hide the format of the disk from your computer, because your computer is not actually accessing the disk – the server is.
But Mac OS X has been able to access FAT32 for quite a few versions now, so I’m not sure what the issue really is here. Are you able to use other disks on this same USB port? Is it a USB1.1 port, and a USB2 device, maybe?
All of the rest are fine. I’ve got 4 externals, but only this one
being the NAS/USB1/USB2. The others are all Firewire/USB.
I’ve tried the cables in every conceivable slot, swapping ports on
the mac, using a hub, connecting directly, daisychaining and all of
the others are fine, just not the NAS/USB, which is viewable in
system profiler but not Disk Utility.
As I mentioned before, it seems to be working okay as a NAS device,
albeit slowly, and accessing folders on it seems to hang the finder
for a few seconds, but I thought that this folder of retrieved 70,000
files may have been slowing a network drive down, hence my attempt to
mount via the USB port.
Thanks for the reply anyway Walter.
server is.
USB2 device, maybe?
