Currently I am facing 2 problems and I hope you experienced people can help me out here.
First problem is:
I want to have a 100% full width header with a navigation bar and logo in it, fixed in window.
However, even though my page has a center align, the fixed in window items ignore that.
Instead, they go in the top left corner. And when I put them more to the right, the page width becomes too big and the website is not responsive for any mobile device or browser at all.
How can I fix this? Can you please make a small Freeway file showing how to do this?
I have send my Freeway file as well, but I have just removed the navigation bar and logo because they werenât centered.
The second problem is that my SmoothScroll action suddenly doesnât work anymore, it says that it is a Javascript error or something and that the action will be ignored when uploaded online. Then, I clear the error, restart Freeway, still doesnât work. It says that it is âtaking too longâ.
I hope somebody can help me out here with these two problems.
Hopefully your first question has been answered in your reply from Freeway Support, regarding the tutorial and sample file on âinline box model layoutâ which you can find on the page at http://users.softpress.com/keith/box_model_tutorial/l
As for your second question, if you go to www.actionsforge.com you will see that there is a very recent update to the Smooth Scroll Action which you should download and install.
thanks for all the support.
However, I downloaded the newest smoothscroll action on actionsforge but it still doesnât work! I restarted Freeway several times and also re-put the action on the page. Is my page too loaded? What do I need to do to get it working again?
I can see no sign that you have applied SmoothScroll to the index page at skyframes.nl. There should be a link to prototype.js, another to scriptaculous.js, and a block of JavaScript in the page head installing the observer function in the page DOM. None of that is there at all.
On Sep 2, 2013, at 5:31 PM, Steijn wrote:
Hi there,
