fad in and roll-over
Is it possible to fade and image in on the page which then turns into a roll-over? Can this be done in Express or would I need Pro?
actionsdev mailing list
After setting up the rollovers, to make the ‘Normal’ image ‘fade’ onto the page:
  1. Select the image and apply the Transition FX action.
  2. In the Actions palette, tick the ‘On Page Load’ option.
  3. In the Effect drop-down menu, choose ‘Appear’.
  4. Tick the ‘Initially Hidden’ box.
The ‘Blind Down’ and Slide Down’ options also make the image appear gradually.
IanB
Only perfect!!
Just the effect I was after, can’t wait until the weekend when I can really start playing.
Many many thanks.
bill
That’s good news.
If you add the Attention FX action, the picture can be made to shake AND fade on to the screen. I’m not sure how useful it is, but it’s great fun and the rollovers still work.
