On Jan 28, 2011, at 9:44 AM, tonzodehoo wrote:
Is it possible to round the corners in Freeway other than with the
box shape?
That is the one way I know of in Freeway. If you set up a scratch page
in your document, with each of the photos placed and corners rounded,
you can export them from there in their compressed form, then bring
them back into your home page as pass-through images. They will retain
their curved corners, and all will be well in all browsers.
If you do it in Photoshop, I would drag all of the individual photos
into one PSD file (as separate layers) and use the rounded-rectangle
tool to draw a mask layer with your desired corners. Move that layer
all the way to the bottom of the stack, and then option-click the
boundary between that layer and the next, and so on, so that all of
the photo layers are “clipped” to the rounded rectangle. Then use Save
for Web to export the top photo, then switch off its visibility,
export the next layer down, etc. until you’re done. Again, bring the
images back into your home page as pass-through images, so you don’t
introduce any double-compression artifacts.
(Fun fact: if you compress a JPEG image over enough times, like
running it through a copier and then copying the copy…, you will
actually end up with a larger file in the long run. All of that JPEG
crawly-edges crud looks like detail to the JPEG algorithm, so it tries
to sharpen and enhance it as it saves, compounding the issue and
reducing the number of smooth areas in the photo that JPEG does such a
brilliant job of compressing.)
I’ve compressed the images down and the largest is about 250Kb. My
broadband connection is not that great but it seems to load quicker
over my connection than sites like the BBC.
That’s really great. If you’re going to do a fair comparison of
download speed, though, you might want to compare with a page that
doesn’t have a server-side application running to assemble the latest
news in response to your click. Even on the Beeb’s speedy servers,
that process does take some time.
With your suggestions I reckon it is running a lot quicker and
smoother. What do you think?
The idea of the big splash of photos on the homepage is to act as a
big friendly shop window to the services which can be found via the
menus.
I think it looks good, I think it will perform much better once you
and your client weed the number of photos down to 3 - 4 total. Explain
that you’ve put that many photos up because “they were all so good, I
had trouble choosing” and then assert your professional authority that
more ≠ better.
Cheers,
Thanks again.
actionsdev mailing list
