See on Bike2 your Div with ID bigbox - try sending it to the back
Item>Send to back
Item>Send to back
Tried that. No change.
Item>Send to back
I assume it works fine when it is not there?
Yeah, to create the example (the links I submitted above) all I did was “duplicate page” of “bike” and past the box in on page “bike2”. I copied the box from my index page. It’s working fine on that page.
Doty
How did you create your navigation?
Is it in a table - can you select it and bring it to front.
Ding Ding Ding! Your question prompted me to turn on html layout and I realized I needed to check the layers box on my buttons! I copied it from an earlier design and must have come in as a table. What a pain.
Now, they are all working, except the one on this page
http://dotyshepard.com/shop/bike3.html
(the one on the ladies ringer shirt). It should be a rollover just like the ones at the bottom of the page.
Any clue on that one? It is a submit button, but it can still be a rollover, can’t it?
Doty
Hey David!
Just noticed something unusual on my page:
If I click the color swatches of the shirt instead of just roll over them, I’m taken to the top of the page. Is there a setting I can put on the rollover to make the page stop jumping to the top?
Everything else seems to be working perfectly, so I want to be careful making changes! Ha.
Thanks again for all your help! Couldn’t have done it without you!
Doty
Yes this is a bit of a quirk but it can be easily fixed.
Have a look at http://freewaytalk.net/thread/view/68020#m_68022
In order to make a rollover effect, there has to be a link to “hang” the effect on. If (as in your case) there is no actual link to a different page, Freeway adds a dummy # anchor link. Most browsers interpret this as a link to the top of the page.
If you click once on your rollover element(s), and add a manual link to each one. In the External side of the Hyperlink dialog, enter
javascript:void()
as the URL. This will not make any sort of page motion when you click.
Thanks guys! It worked like a charm.
Doty
