Gray_Owl
(Gray Owl)
March 3, 2010, 7:29am
#1
Hi All
OK, so what am I doing wrong. Have followed both the set ups from LLE and Cabels Blog and have read the rest of the post’s on this subject but I can not get it working.
To see what I mean have a look at http://www.brutontown.co.uk/testsite/index.html and click on the first image.
I’ve put the two lines of code on page> markup> Before and tried the ‘Onload’ extended attribute on both page and item.
Click on the image and yes it will open on a new page but does not zoom.
Any ideas as to why its not working??
Regards
Your images that you have uploaded for the Zoom are psd files - this is certainly not going to help.
Also do not to put spaces in your file names - instead use underscores.
Gray_Owl
(Gray Owl)
March 3, 2010, 8:38am
#3
Hi David
Now the X in the top left corner is not showing and I have upload the ‘images-global’ folder as well.
Nearly there. Thanks for your help.
Regards
Upload the images-global folder to your Root ie
http://www.brutontown.co.uk/images-global/
Gray_Owl
(Gray Owl)
March 3, 2010, 5:56pm
#5
Thanks for your help, David. All is working well, now.
Regards
Lee
Good - I am glad you are sorted but ScriptyLightbox would have done a very similar job - easier.
