Dave1
(Dave)
March 24, 2011, 10:44am
1
Hi,
I’ve applied all the necessary markups and transfered the FancyZoom file to my server. For whatever reasons, FZ is not working. I use Host Gator. Any suggestions?
Dave
Dave1
(Dave)
March 24, 2011, 10:48am
2
Update: I use FancyZoom on another site which works perfectly. This site is hosted by - Network Solutions. I built both sites with Freeway Pro 5.
waltd
(Walter Davis)
March 24, 2011, 5:38pm
3
I haven’t used it at all, but I think that FZ is simple JavaScript –
there’s nothing terribly server-dependent about it. If you go through
the install steps one at a time, and just confirm that the files have
all been uploaded to the same spot where your page is looking for
them, this should just work.
On Mar 24, 2011, at 6:44 AM, Dave wrote:
Hi,
Dave
Post a link to your page(s) and we should be able to tell what is missing.
Dave1
(Dave)
March 25, 2011, 12:47am
5
Click on any thumbnail - http://retropower.com/services/panel.html
Thank you
ReferenceError: Can’t find variable: setupZoom
The code shows the scripts as being looked for in a specific path:
/FancyZoomScripts/js-global/FancyZoom.js
Is that how you have the files organized on your web server? If not…
This is code from one of your images
<img src="Resources/DSCN1843_thumbnail.jpg" border="0" width="247" height="185" alt="DSCN1843thumbnail" style="float:left">
and mine
<img src="../Resources/clubpenguinpengu-9.jpeg" border="0" width="157" height="116" alt="ClubPenguinPenguins2" onload="setupZoom()" style="float:left">
See the difference
onload=“setupZoom()”
Bingo!
Dave1
(Dave)
March 25, 2011, 1:20am
10
@chuckamuck ,
Yes, path states as-
@DeltaDave ,
I’m not sure where to locate the ReferenceError. I have the Extended Attributes set as Name: Onload - Value: setupZoom()
HTML Markup:
Dave1
(Dave)
March 25, 2011, 1:25am
11
@ Delta Dave,
Hmmm, how do I set the variable if Extended Attributes already shows set as Name: Onload Value: setupZoom()?
I am not seeing it in the code on your page.
How are you adding it?
Dave1
(Dave)
March 25, 2011, 1:34am
13
Freeway Pro 5 - Page>Extended>New - Type Onload for Name and setupZoom() for Value.
FancyZoomScripts folder is on the server in my home directory.
Dave1
(Dave)
March 25, 2011, 2:31am
15
I was able to locate the issue. I removed the markup and extended codes from the page, re-started freeway, then re-applied the markup and extended codes … FancyZoom works perfect. Odd! For some reason, freeway did recognize the codes even though freeway showed the codes as applied.
Thanks for the feedback. Cheers.
Dave1
(Dave)
March 25, 2011, 2:36am
16
This actually will be a headache because I have to remove/re-apply the codes for each page. Has anyone dealt with this issue before? Is this a bug? What is the best way to inform Softpress regarding this issue?
If you have an issue like this again - where the code isn’t actually getting into the version on the server.
Then hold down the Ctrl Key and File>Publish Everything and then upload again.
