Fillable order form pdf problem
Hi
I have generated a fillable pdf order form that the client wants to be filled out and 1 click attach & email back from website in browser.
Some browsers allow fill in but reply button won’t activate in most browsers. have been advised against this method as too many variable browsers etc.
Does anyone have a workaround that does not involve creating a huge 220 product form in Freeway? Would prefer pdf solution if there is one.
Thanks Dags
http://www.scottrobinsonexports.com.au/whatsfdtest/order1.html
You could use Acrobat to create your form
http://www.adobe.com/uk/products/acrobat/form-creator.html
Thanks Delta Dave for your response
I am looking into it. Need acrobat XI and also ongoing costs for over 50 response items (order page over 220 items).
Has anyone used Forms Central embedded forms in Freeway Pro 6?
Dags
It is a while since I used an Adobe Pro created form in a site but then the contents are sent as an email - no Form Central processing.
I assume that you can still do it this way.
