It was in FWP4 but I can’t find it in FWP5. Am I missing something?
Hi Ade,
This function is now called the more generic “Fit Box to Content”.
It’s in the Edit menu; the shortcut is the same as it was in Freeway
4 (Command-Shift-D). It was changed to highlight the fact that this
command works for both graphics and text; if you select an item
containing text and choose Edit > Fit Box to Content, it will be
resized vertically to fit the text.
Stewart
And when I say the Edit menu, I mean the Item menu…
Thanks Stewart. It was a command I used frequently, having created content in Photoshop for example, so my heart missed a bit when I couldn’t find it.
Thanks again.
It’s in the ‘Item’ menu: ‘Fit Box to Content’. Shortcut is still the
same, Apple-Shift-D, and it’s also in the contextual menu if you
right-click on the box.
best wishes
Paul Bradforth
