hello,
just wondering if something like this is possible in freeway and how it might be done…
If you visit this link, the effect I’m after is on the box on the far right hand side (return to top, permalink etc…).
When you scroll, the box first moves to the top of the screen but then ‘sticks’ and stays in position after a certain point so that it’s always visible…
http://new.myfonts.com/whatsnew/last21/fonts/#return_to_item_32
I’ve managed to do something like this with the ‘fix the position in browser’ check box, but what I’m really after is how to make it move at first, and then stick as in this example. I’m guessing it’s probably a layer that is made visible at a certain point in the scroll?
Anybody know?
Many thanks,
Ed
