There isn’t a Flash Trouble list, but there are FreewayTalk (main
discussion), ActionsDev (for and by Action authors), Dynamo (for and
by hand-coders or CMS wranglers or other “dynamic” Web types), Off
Topic (for water-cooler stuff), and Tutorials (for those sorts of
things). If you want to start a new Flash Trouble thread, just create
a new thread in one of those lists.
If you’re using the Web interface, then to start a new thread, go back
up to the main list page (click on the list name in the main
navigation or the footer) and the form to start a thread will be at
the bottom of that page.
If you’re a mailing list member, just create a new message to the
desired list with your thread title as the subject.
And if you’re naming files with spaces in them – please stop. This
will almost never work the way you expect it to.
If your SWF player “skin” looks for the FLV movie file to be in the
same folder as itself, just apply Upload Stuff (action) or Extra
Resources (action) to the same page where you placed the SWF, and use
the Action to get Freeway to upload the FLV to the Resources folder.
On Mar 26, 2009, at 11:30 AM, William Thomas wrote:
I’m new to Freeway Pro. And this isn’t meant to be a reply, it’s
meant to be a new post within the Flash Trouble list. So, if
someone can tell me how to start a new post in this list, that would
be great.
My actual post is simply to say, I am previewing a flash video
wrapped in a .swf shell with a player just fine. I use Fetch to put
them on my site, and all I get is a blank page where the video
should be playing. I have placed .flv and .swf and the player .js.
Again, it previews the page fine, AND it previews in local browser
(Safari) fine, but here’s what I see when I check the online version:
http://www.brightideascreative.com/HCvideo_flash.html
Could it have something to do with spaces in the names of the .flv
and .swf that are in the Resources folder? A sample name is:
“Harrison County final 576c_player.swf”
