I’ve just started putting some flash stuff in sites, and I was wondering… what is the best way to implement Flash with Freeway? I’ve been just loading the SWF file into a picture box.
If people ask for the html files, (outside of Freeway) I’m assuming they want the .html file, javascript file, and the swf that Flash produces when you “publish.” Right? Is there a best setting, and or way for use in programs other than Freeway?
I’d recommend using “Save For Archive” in Freeway when it comes to passing around files. This will output, into a folder, only the files used within the project. Just like “Collect for Output” in Quark. Then what you’ll have to do is then just delete the Freeway file from the outputted folder if the user doesn’t have Freeway or is on a PC or leave it in there if they do since it will duplicate your existing file.
Sometime around 23/3/09 (at 14:45 -0400) Dan J said:
[…] or leave it in there if they do since it will duplicate your
existing file.
Be aware that the Freeway document will include whatever upload
name/password details you may have in the current document. If you’re
giving someone a site docujment as an example rather than as handing
over responsibility, best remove such details first.
