Sometime around 22/12/08 (at 06:29 -0500) Mr worm said:
When I import the .swf file into a html item ‘628x313’ and preview
it, the scale is much smaller and not to size???
Curious. I just tried this with one of my Keynote presentations and
it stayed the same size in Freeway and the browser as it was in
Keynote.
Try dropping the SWF file directly onto the page. Does it arrive at
the size you want?
If this is still a problem then try applying the Flash Extras action
to it. Select it and choose Item > Actions > Flash Extras. Then in
the Actions palette set the Edit Movie option to Yes and enable the
Scale Movie option. The Flash movie should be scaled to fit your box
when you preview in a browser. (Note that it wil scale to fit, not
scale to fill. You won’t end up with part of the movie cropped off if
your box isn’t the right ratio. Give the box itself a colour fill to
see how this works.)
I tried dropping it onto the page, it appears even smaller??
I don’t seem to have the flash extras action. But a ‘flash extras mod’ action??? However none of the palette options you state here are available. Do you have a link where I can download the action. Can’t seem to find it?
At present I am drawing a graphic item, importing the swf file, setting the item dimensions to that of my keynote file 628x313. Once previewed, it has white and black space around it in the area with the flash file playing within that item.
I just don’t get it K, if you say your works fine!
