For a HTML Item in FW 5 Pro - where can I set the “float” and “clear” options as these two settings don’t appear under my Dimension section of my Inspector palette when selecting a HTML Item?
Tony.
Float and clear only relate to inline html boxes. If you want to add float and clear to a graphic object for example, first create an inline html box which you will apply the float and clear to, then insert a graphic object into that.
The float and clear options for inline boxes appear under the first tab in the inspector pallet.
You draw a parent HTML object, then click inside of that HTML object
so you see a text cursor, and then use Insert > HTML Item to add the
child object.
On May 22, 2008, at 11:40 AM, Tonsils wrote:
Thanks but from the looks of it, I don’t think I m creating an
inline html box correctly - how do I achieve this?
If the item is inline, you’re not dragging it anywhere in the page panel. You can drag it directly around inside the item it is within (though I highly recommend against that).
The output code for inline items is indistinguishable from parent/child items. However, working with inline items in Freeway is very different from working with parent/child items. It takes a while to get the hang of it.
On Thu, May 22, 2008 at 8:26 PM, Tonsils wrote:
Thanks for that - all good now. The only thing is though, I can’t seem to create a sub-item type structure like in Todd’s Liquid example.
I can manage to create the inline html items but in the site/page panel on left-hand side, I can’t drag a sub-item under a parent item.
