Julie1
(Julie)
September 27, 2012, 5:20pm
#1
Good Afternoon,
I am having a font / HTML box issue…
I type in the words into an HTML box. (layered)
I then select the words and change the font to a font set I made (savoye)- and I have caxton on the page too (in the pasteboard unlayered) -
I see the changes - and i have to do a -1 shift to make it centered (unsure if it is the font or what)
so i then publish and I cannot see the words.
I click on the HTML box and bring it forward.
preview - still no words
WHat am doing wrong? or what can I do to fix it so I can see the words.
thanks
Julie!
Julie1
(Julie)
September 27, 2012, 6:02pm
#2
PS I tested it out next to a word in proportional - and that word shows not the word in savoye…
so do you think it is the font? It shows as a graphic text not an html - even though I set up the font, font squirrel etc…
How can I fix this so it shows? thanks!
Julie
On Sep 27, 2012, at 1:20 PM, Julie Maxwell email@hidden wrote:
Good Afternoon,
thanks
Julie!
Can we see it online somewhere?
Julie1
(Julie)
September 28, 2012, 12:53am
#4
Thanks!
Here is the real “temp” site:
www.grassrootsweb.net/ray
if you see there are 6 boxes that transition in on the bottom: these are all graphic texts (which I would want as HTML (even using the Caxton)
so, I did that
Here is the problem one:
www.grassrootsweb.net/ray2
If you see on 6 boxes the 3 on the left of the screen are the graphic txt again.
The 3 on the right are the html text with savoye font and using Caxton.
the bottom box on the right has both regular proportional html text and the html w savoye text
I did this so you can see all the examples of what I described before.
This is also the site that i wanted the sub menus to go out horizontally not vertically and put engagement rings on 2 lines …
Thank you for all of your help!
J
Your problem is that the definition you have created in the style for savoye is savoye but it should exactly match that in the FontFace css file which is savoyeregular
You have
.style9 {
font-family: Savoye;
font-size: 36px;
and it should be
.style9 {
font-family: savoyeregular;
font-size: 36px;
but you should add fallbacks for Browsers that dont support this such as
font-family: savoyeregular, Times, serif;
And check your spelling! REFURBISHING
Julie1
(Julie)
September 28, 2012, 2:03pm
#6
Perfect…
also referbishing was just a dummy place holder to show the problems it is now gone.
Thank you!
You have
.style9 {
font-size: 36px;
and it should be
.style9 {
font-size: 36px;
