Font problem - it changes !
Hi
I have worked on a web page for some time now and suddenly today, the fonts are making big problems!
I use Verdana on the entire page, but what comes out is definetely not Verdana. Neither in the edit mode or preview mode. And it says Verdana in the Inspector.
I have not uploaded this yet, so on my page online everything is still ok.
I use Tiger at work, Leopard at home, and Freeway 5.
I swapped between my home computer and work before without problems, so I do not think that is the problem.
What happened ??
Within 1-2 weeks it must be ready, because our company has just ordered a domain swap. I am a little unhappy now, actually, since I am in charge of that !
Here you can see the initial layout: http://www.loslekt.com/utr/index.html
We just have to change a lot of the content and also add some more pages.
What I see is verdana, but all the fonts are graphic text - which the search engines won’t see.
Try making/converting the text into HTML.
David Owen :: Freeway Friendly Web hosting and Domains ::
http://www.ineedwebhosting.co.uk :: http://www.ineedwebhosting.co.uk/blog
I create boxes and apply text - thought that was it!
I feel like I have missed something here :wink:
Is there an easy way to do this or do I have to go through all the text.
Perhaps I need to read some instructions more carefully.
Two type of boxes, graphic, or HTML you need the HTML boxes.
You can convert your text and boxes in the inspector palette.
