On 1 Jun 2008, 9:34 pm, chuckamuck wrote:
Maybe this link will help you out. http://www.freewaytalk.net/thread/view/29585#m_29732
Nope. The issue here is that if the window is enlarged greater than the content, the page background draws underneath the footer and the footer is not at the bottom of the window.
On 1 Jun 2008, 9:45 pm, chuckamuck wrote:
…or perhaps this link: http://www.freewaytalk.net/thread/view/10221#m_10222
Both the above method, and the following method are dicussed in this thread, but neither of them work as desired.
On 1 Jun 2008, 9:46 pm, Mitchell wrote:
This sounds like what you’re looking for:
http://www.thebigerns.com/freeway/footer/
This is exactly what I had originally done, and have gotten the same results. You will notice that as soon as you resize this window to the point where the content invokes scroll bars, that scrolling the window up prevents the footer from remaining at the bottom of the window.
You can work around this by having your content in non-layerd items, but if you then want some of your footer to overlap the above content you will not have the option to have the overlap “behind” the content (as I wish to have).
I discovered that simply drawing out a non-layered blank html item will give the footer something to butt up against (and maintain the layering of the footer and the content) and I guess that is the solution.
If you want to see what I am talking about have a look at:
http://www.aboutpollockpines.com/accommodations.html
So for now the issue is resolved. Thanks!
