Form element styler on focus text
Am I correct in thinking that the FES action which has the onfocus and onblur options allows for text to be added to form fields?
If so, it doesn’t work for me. Is something else required?
Just downloaded the latest version and the Extended onfocus / onblur is no longer in the action.
I have seen a few posts relating to the form field text - seems a simple thing to have, but managed to get it working. Is there a simple explanation/example?
Hi Nathan,
  1. Select the form element
  2. Select Item > Extended
  3. Select the Input tab (if not already selected)
  4. Click the New… button
  5. Enter
    value: anything you like really
  6. Press OK
  7. Press OK (again) to return to your Freeway page
  8. Preview and your placeholder text should be displayed in the form input item
  9. Make a decision if you care about the page not validating in less than HTML 5 pages
  10. There is no step 10!
Experienced Freeway designer for hire - http://www.freewayactions.com
Make a decision if you care about the placeholder text only appearing in IE 9 or above.
On Oct 25, 2012, at 8:55 AM, Tim Plumb wrote:
  1. Make a decision if you care about the page not validating in less than HTML 5 pages
Oh, and to be clear, this only refers to IE – Safari, Chrome, Firefox, Opera – all the “long-pants” browsers – will display this properly.
I knew there must have been a step 10!
Thanks folks. Much appreciated.
So I would have to employ another method for IE 8 and under?
I suspect javascript?
Yes. What I would do is employ a “polyfill” for the standard behavior. Basically, it’s a JavaScript “shim” that only fires when the correct standards way of doing it won’t work. That way it only annoys the IE 8 and lower users, rather than slowing everyone else down as well.
Let me see if I can dig something out, I’ve solved this problem about a hundred times.
Okay, this should work for you:
Apply the Protaculous Action to your page, choose Prototype-packed from the Library picker, and paste in that code. The only tiny wrinkle here is that the script will never let you enter the placeholder text as the actual entry value, so choose your placeholders wisely! (This will only be an issue if someone named First Last tries to submit your form with IE.)
Have applied that to the page, but nothing has changed in IE8.
I pasted it in the first function dialogue box.
http://www.newyoubootcamp.com/promotions.html
I corrected the Gist to use a better test for placeholder support. Copy the code again and update what you pasted into Protaculous.
http://scripty.walterdavisstudio.com/placeholder.html
You also have a zillion JavaScript errors on your page, mostly to do with cross-domain requests from Twitter or something like that. Develop / Show Error Console (in Safari) for the hideous news.
Hmm the errors are annoying. Those twitter buttons etc. are the ones freeway inputs
Thanks for the updated gist Walter - works a treat.
