formmail clone script
Good Morning,
AS we know we all learn something new everyday.
I have learned that the PHP FF action does not work in an https setting.
I have been directed to use the formmail clone available on my server.
I was just looking at it - where it says the script is I am getting the following line:
FormMail-Clone Version: 2.4
This is FormMail-clone, a clone of FormMail.cgi. It is a clean room version for legal purposes (a less restrictive liscense), but should behave the exact same way as Matt Wright’s Original, but contain none of his code.
but nothing else. but I am unsure how to set it up etc. if i don’t have access.
I am lost. Thank you for your prompt help!
Julie
I’m a little surprised about that. Can you say a little more? What
leads you to this conclusion?
setting.
That would be me Walter! :slight_smile:
The PHP that the action creates looks for cross domain posts and
blocks these in an attempt to stop spammers posting directly to your
PHPFBF code. It appears that there is something in there (I’ve not had
the time to look closely at it) that is causing this to fire when
Julie uses her form under an SSL connection.
I could strip the checks out in the code and that may work around the
issue but I really need to find time to test this on a secure server
and see where the error is.
FreewayActions.com - Freeware and commercial actions for Freeway
Express & Pro.
Spam.
http://www.freewayactions.com
Ah. If one of you could post a Gist or Pastie with the complete
contents of the formname-go.php file, I might be able to help you spot
the loonie.
had the time to look closely at it) that is causing this to fire
when Julie uses her form under an SSL connection.
the issue but I really need to find time to test this on a secure
server and see where the error is.
Express & Pro.
Spam.
All that to say, I wouldn’t start trying to port over to FormMail from
PHPFF – they’re such completely different animals, and FormMail is a
real bag of hurt.
spot the loonie.
your PHPFBF code. It appears that there is something in there (I’ve
not had the time to look closely at it) that is causing this to
fire when Julie uses her form under an SSL connection.
Express & Pro.
Anti Spam.
I dont know where that is… sorry.
I cant even see the script for the formmail.
But any help would be great. Just to bring you up to speed Walter and everyone else,
the page of my site form is:
https://faithsatellite.com/ordernow.html
i get the not in domain error
Julie
On Oct 13, 2010, at 12:15 PM, Walter Lee Davis wrote:
All that to say, I wouldn’t start trying to port over to FormMail from PHPFF – they’re such completely different animals, and FormMail is a real bag of hurt.
Ah. If one of you could post a Gist or Pastie with the complete contents of the formname-go.php file, I might be able to help you spot the loonie.
The PHP that the action creates looks for cross domain posts and blocks these in an attempt to stop spammers posting directly to your PHPFBF code. It appears that there is something in there (I’ve not had the time to look closely at it) that is causing this to fire when Julie uses her form under an SSL connection.
I could strip the checks out in the code and that may work around the issue but I really need to find time to test this on a secure server and see where the error is.
I’m a little surprised about that. Can you say a little more? What leads you to this conclusion?
FreewayActions.com - Freeware and commercial actions for Freeway Express & Pro.
Hi Walter,
Thanks for the offer. It turns out that Joe at Softpress updated the
action to work with SSL issues.
I’ve posted his corrected version of the action on my code store area
until I get a chance to update the FreewayActions.com site.
Here’s the link; http://tinyurl.com/32r4yme
or http://www.freewayactions.com/code/?f=php+feedback+form
Julie, download the action and replace the version you have. Publish,
upload and test your site and see if this helps.
spot the loonie.
Express & Pro.
Spam.
Julie
Hi Julie,
Just to be clear, visit the link below, click on the download link and
install this version of the action in Freeway (replacing the old
version you already have), publish, upload and test your site.
Let me know how you get on.
Express & Pro.
Spam.
Click the Download File button in the middle of the top bar.
On Oct 13, 2010, at 12:46 PM, Julie Maxwell Allen wrote:
I did get that LOL.
All im seeing is code.
when I open - it opens text editor. I try to switch to program to FW
in the finder info window - would not let me.
Julie
On Oct 13, 2010, at 12:43 PM, Tim Plumb wrote:
Hi Julie,
and install this version of the action in Freeway (replacing the
old version you already have), publish, upload and test your site.
Express & Pro.
Anti Spam.
I did,
I get a white paper.
when i open it - goes to txt editor.
when I go to finder - info - I try to change the program to FW and I cant.
I can do dreamweaver - but not FW
J
I did get that LOL.
when I open - it opens text editor. I try to switch to program to FW in the finder info window - would not let me.
Julie
Hi Julie,
Just to be clear, visit the link below, click on the download link and install this version of the action in Freeway (replacing the old version you already have), publish, upload and test your site.
Then drag that white paper over Freeway’s Dock icon and let it sort
out the fact that it’s an Action. It will.
On Oct 13, 2010, at 1:01 PM, Julie Maxwell Allen wrote:
I did,
I cant.
J
I did get that LOL.
Julie
Hi Julie,
site.
Express & Pro.
Anti Spam.
Did not know that!
it works perfectly!! Tim, Walter, Dave and especially Joe for this action … words can not express how grateful I am for all you do!
Julie
On Oct 13, 2010, at 1:07 PM, Walter Lee Davis wrote:
Then drag that white paper over Freeway’s Dock icon and let it sort out the fact that it’s an Action. It will.
I did,
J
I did get that LOL.
Julie
Hi Julie,
