Hi,
I’m looking for advice on how to impliment the “captcha” facility using Freeway and Forms To Go. I would appreciate any help or advice as a client has recently started getting spam via the contact form on their website. The script was generated using Forms To Go.
Thanks David. That’s a really neat set of actions - easier than Forms To Go.
The only problem I have with easiForm and easiCaptcha are that you have to pay per domain, whereas Forms To Go generates scripts for any number of domains.
Oh well you can’t have it all. I do like the easiForm/captcha option better however and will use it in preference to Forms To Go in future. I’ll just pass the cost onto the client.
Thanks again for pointing out this great solution.
