hi!
i’m new on working with freeway for my partners homepage. he always uses freeway 4 pro with his mac. without thinking about freeway he updated his mac on 10.9 osx. now i can’t update his site because freeway is crashing after the instruction “upload”…
any ideas?
thanks!
He can still use Freeway 4 under Mavericks, as long as he doesn’t use it for uploading. Transmit (and other SFTP apps) has a “Synchronize” command that is very similar to Freeway’s Upload command. Have him use that until he gets around to updating Freeway.
On Feb 4, 2014, at 7:29 AM, lisley wrote:
hi!
any ideas?
thanks!
The ‘synch’ command is in Panic Transmit, not Freeway. Try the 30-day trial: http://www.panic.com and see if you can get it to work. I wouldn’t recommend updating a Freeway 4 document straight into Freeway 6 – it’s possible, and for a simple site, it may work just fine, but you may end up with a lot of time sunk into troubleshooting layout differences.
But don’t get me wrong here – by all means, buy Freeway 6, and use it for any new projects you create – it’s a truly great upgrade. But leave this document in Freeway 4 until you can invest the time to start over and re-create it from scratch.
On Feb 4, 2014, at 8:20 AM, lisley wrote:
thanks for your answer. unfortunately there isn’t any sync command. so we have to update freeway first…
ok, don`t know what panic is before. thanks for your help. I´m really new on creating pages so i´m overwhelmed with panic
i found another solution: my 10 year old macbook pro with 10.5. updated the site although i would not think that this mac boots again. but it works after waiting about 4 hours boot-process
lisa
