There are new versions of Freeway (5.6.2) and Showcase (1.1) available. Download them now on our shiny new website (http://www.softpress.com, in case you weren’t sure). The download links can be found on their respective product pages, Showcase is included in the download.
Thanks! Already downloaded and installed this one. Doing some improvements on my website www.dtp2.nl and it should be up and running generated by the new Freeway Pro asap.
I am doing the update now and I get the following pop up:
“The operation can’t be completed because some items had to be skipped. For each item, choose File > Get Info, make sure “Locked” is deselected, and then check the Sharing & Permissions section. When you are sure the items are unlocked and not designated as Read Only or No Access, try again.”
This is after I authenticate the move into the application folder
I am on Lion.
There is no list of what was skipped = What should I do?
THanks,
Julie
On Dec 20, 2011, at 2:50 PM, Joe Billings wrote:
Hello FreewayTalkers,
That sounds like a Mac OS message. Are Freeway or Showcase locked in the Finder? Follow the steps in the dialog for both applications and try again.
On 20 Dec 2011, at 20:43, Julie Maxwell wrote:
Hi,
I am on Lion.
THanks,
Julie
Hi,
I am on Lion.
THanks,
Julie
J
Hi,
I am on Lion.
THanks,
Julie
J
Hi,
I am on Lion.
THanks,
Julie
J
Hi,
I am on Lion.
THanks,
Julie
The other FWP says that it is a downloaded program found on the disc freeway55pro562.dmg I have opened saved a file closed and when I open it - keeps directing me that way.
BTW, I meant my programs are in launchpad not mission control - sorry.
So, any suggestions?
ALso, I don’t know how to check if the “original” FWP is locked or not.
Thanks. This is the first time ever I have had issues with updating etc FW.
J
On Dec 20, 2011, at 4:57 PM, Julie Maxwell wrote:
Ok all I was told was to
Close it. I have never had issues before. So, how do I see that? All my apps are in mission control
Sent from my iPhone
On Dec 20, 2011, at 4:45 PM, Joe Billings email@hidden wrote:
Are you replacing the existing version of Freeway? It’s that one that might be locked.
J
Hi,
I am on Lion.
THanks,
Julie
What - No Gallery of sites for us to check out on your shiny new site? I can see that there may be some, mine included, that are not the best advert for SP and need to be culled. But could the good ones be placed somewhere here in Freeway Talk, as a reference for registered users - or something?
And no support for Ineedwebhosting? Just Fatcow? Shame! Give some support to the home teams. After all it does say “Made in Great Britain” at the bottom
I’m not too sure what to suggest, other than completely removing your existing Freeway and Showcase applications and reinstalling them from the disk image.
Launchpad is just an extra interface over the applications in your Applications folder, so that shouldn’t make a difference.
We’re showcasing sites that we particularly like on the individual product pages. We’re still thinking about the process for selecting these. As always, we welcome people sharing their sites with other Freeway users, whether it’s on here, Facebook, Twitter, or Google+.
The site is a work in progress, so watch this space.
(And no senior or student discount anymore?)
We are still offering education, non-profit and senior discounts.
Downloaded then double clicked…
Did you copy it to the Applications folder and then double-click THAT
one? Or did you double-click the one that is in the disk image? Sorry
for the dumb question, I just want to check.
Did you copy it to the Applications folder and then double-click THAT one? Or did you double-click the one that is in the disk image? Sorry for the dumb question, I just want to check.
