Robert_B
(Robert B)
January 6, 2014, 2:28pm
1
Thinking about upgrading to Mavericks and was wondering if FW 5.6.5 works OK in it.
I have FW 6, but still use 5 for older sites.
I assume FW 6 works in Mavericks without problems…
Thanks.
Bob
waltd
(Walter Davis)
January 6, 2014, 2:32pm
2
Everything except the Upload function. If you want to use Freeway < 6 in Mavericks, you must use a third-party (S)FTP application like Transmit or Fetch to upload your sites. Transmit has a very similar feature to Freeway’s “smart upload”, if you use the Synchronize feature to mirror your local Site Folder to the site root on your server. Just be sure to add _siteinfo to your list of files to ignore on upload.
Yes. Works really well.
Thanks.
Bob
Robert_B
(Robert B)
January 6, 2014, 2:35pm
3
Thanks, Walt.
Have Transmit. In fact, for some reason, I usually use that anyway rather than FW’s built in feature.
I think I had a problem using that a while back and just stuck with Transmit.
Thanks again.
Bob
5.5 upload actually works fine. In < 5.5 the upload doesn’t work in Mavericks because the library it uses has been removed.
Stewart
waltd
(Walter Davis)
January 6, 2014, 3:35pm
5
Sorry, I misremembered the break-point!
Stewart
jmuscara
(Joe Muscara)
January 7, 2014, 2:03pm
6
Yep, I’ve been using 5.6.5 under Mavericks since Mavericks came out with no issues whatsoever.
