Freeway 5 Reference Guide?
Freeway 5 Manual mentions the Freeway 5 Reference Guide but I can’t
seem to find it online.
http://softpress.com/support/usermanuals.php
Not online yet?
Someplace else?
If not ready is there a targeted release date?
Craig
in the help menu/using freeway
brings up a pdf file
Not online yet?
Someplace else?
Craig
Hi Craig
Have a look at
www.softpress.com/support/usingfreeway.php>
Is that what yoyr looking for.
Regards
Lee
in the freeway 5 pro help menu “using freeway” brings up a 120 page manual.
Not it?
That I found. It’s mostly tutorial. There was a big Reference Guide
PDF with Freeway 4. Like 18 chapters and nearly 500 pages I think
(April 2007). I was wondering if an updated PDF will be available.
manual.
Not it?
We are indeed planning on releasing an update to the reference guide.
We have no definite date for this as of yet though.
Joe Billings
Support Technician
Softpress Systems Ltd
http://www.softpress.com
manual.
Not it?
Hi Mr Billings - I had the same thought - where is the 5 reference that is referred to - you may still not have a release date so in the meantime is it OK to use the version 4 reference (ie it won’t make for too much confusion) ?
Regards Roger
Yep, version 4 of the reference will be fine for the moment. It just
has some slightly different interface references and won’t have any of
the new features in it.
Regards Roger
I’ve still got my 3.5 User Guide (nearly 400 pages – absolutely invaluable. I look forward to a new version.
