I designed my website with Freeway 5.6.5. If I ugrade to 6.0.8 will my desgin change ? In other words do I have to make a lot of corrections in 6.0.8 so it will look like in 5.6.5. ? I don’t want to use the trial to check.
What are the main reasons I should upgrade to 6.0.8 ??
I don’t think you ‘need to’ upgrade … it’s more like ‘do you want to upgrade’. If you do, remember that some actions you might have used might not be FW6 compatible (yet).
Most sites will be ‘converted’ just fine into FW6, it kind of depends of how you’ve set it all up.
Again, when you don’t feel the need to upgrade, don’t.
But … why not just download a 1-month fully functional trial of FW6 and fiddle around, see what it does for you …
