Hi All
I have been using OSCommerce for a while and have found it an ideal shopping cart system for both the client to update and also for the designer the build with.
I have recently come across a contribution for OSCommerce called STS or Simple Template System, enabling all the php elements within OSCommerce to be built into an html template.
Has anyone had any experience with this and has any advise with using FW to build the template on which the OSCommerce elements are placed.
TIA
Tim
dynamo mailing list
