Sometime around 28/5/08 (at 10:29 -0400) Tonsils said:
Are there any people out there that have extensively used RW and
have resorted back to FW - if so, why?
I’m afraid that I can’t answer as someone who has spent significant
time as a RapidWeaver user - but that’s because its basic approach to
site creation isn’t one that fits with my desire to build custom page
and site designs.
RapidWeaver is a very well made tool, one that presents the user with
a pre-built abstract of a site structure that is waiting for content.
Freeway is also a very well-made tool, and it is one that presents
the user with a blank page and the tools of a professional designer.
Which approach works best for you really depends on which approach you prefer.
When it comes to coding, i.e CSS/Javascript/Ajax - which of the two
does it better.
In terms of the code that is produced, they both do a great job…
RapidWeaver does so because that’s how the templates and the core
engine work: as long as you use a well-made template, the engine will
deliver well-made code.
Freeway does so because that’s how its sophisticated code generation
engine is designed to work: you create your own layouts and pick the
settings you want, and it works out the optimal standards-based code
that will produce your efforts in HTML form.
Each allows the user to screw things up if they try hard enough, but
in both cases that will involve adding invalid or simply incorrect
custom code by hand; the stuff the tools themselves made is fine.
Okay, it isn’t entirely down to plain end-user error: in Freeway, a
buggy third-party action could produce problems in the output. In
RapidWeaver a buggy third-party template could produce problems in
the output. But same difference really, and still the same
conclusion: the tools themselves work well.
Which has the bigger customer base?
An interesting question, but I’m not sure how relevant it is. The
customer base for Microsoft Word is massively larger than the
customer base for Adobe InDesign - but other than the fact that both
are used to assemble content on pages they are two massively
different products and are used for rather different jobs.
Freeway and RapidWeaver aren’t quite as dramatically different, I’ll
grant, but they are designed to satisfy quite different publishing
needs.
Also, I’ve no idea which has the biggest customer base.
Any help?
k
