I am running into a big problem. I have a program that generates code from the back end to create a form with javascript functions that check if your email is valid, etc.
When I create an html file in a text editor, the script works perfectly.
When I create a Markup Item in Freeway and preview, the script doesn’t work at all.
Here is what the correct, working line of code is coming from the back end:
ar mailPattern = /^([A-Za-z0-9_-.])+@([A-Za-z0-9_-.])+.([A-Za-z]{2,4})$/;
Here is what Freeway mangles it into:
ar mailPattern = /^([A-Za-z0-9_-.])+\@([A-Za-z0-9_\-\.])+.([A-Za-z]{2,4})$/;
I really need this script to work for me in Freeway. It’s very annoying and time consuming to have to preview the file, and go into a text editor to correct it so that it works. Any information will be greatly appreciated. Thanks in advance.
