I’m considering upgrading to FW Pro 5, my question is regarding the new css menu feature.
When building a css menu there is the ability to use a background image to customise your menu. I would like to use multi-couloured background images for my site. Does this menu action limit you to one image? Is there a work around?
Right now the action only allows you to set one for current, hover, and just general background. It appears each “option” in the menu uses the same style so it doesn’t appear you could set a specific background on a per-item basis.
It’d be nice, along with having each item be sized based off the amount of text in there. Features I hope Softpress will adjust.
