On 11 Apr. 2008, 9:59 am, ktam wrote: > > The sequence click action is not included with Freeway, but you can download it from the softpress website: > > http://www.softpress.com/kb/article.php?id=162 > > Or, since it looks like you have used the action previously then you can find it on your computer. If you upgraded from Freeway 3.5.X then you should have a Freeway Actions folder next to where your Freeway 3.5.X application was and you can find the action in that folder. If you upgraded from Freeway 4 then your action was probably installed into the actions folder inside your home Application Support folder. > > ~/Library/Application Support/Freeway 4/Actions/ > > If you are using Freeway Express then you will have to look in: > ~/Library/Application Support/Freeway 4 Express/Actions/ > > Kevin > > > > > > >
Thanks, I downloaded it again (and the modified Slave Image that allows for 60 images) and all it good.
