I’m using Freeway Pro 6. I have set up multiple SEND FORM actions on my site. Some work and some don’t. This is the message I get when fill out the form and send it:
“Parse error: syntax error, unexpected ‘S_LAST_NAME’ (T_STRING), expecting ‘)’ in /homepages/41/d362409333/htdocs/tue/weekly-classes/FW_SendForm_registration-for.php on line 79”
I have NO idea what any of it means. I don’t do any code. Any solutions (easy solutions!)? Thanks in advance, Adam
Try removing the apostrophe in the Name field of the Inspector palette for the Child’s Last Name form item. If that works then go through all your forms that aren’t working and remove any apostrophes from them.
