I’m interested in trying out Freeway Pro to create a CSS site and taking advantage of a few features that CSS seems to offer over… frames.
Yeah, frames.
I want to create in effect, a three-frame setup.
Top - fixed, centered with a discreet tiled background pattern.
Bottom half in 1/4 and 3/4 layout. 1/4 is static, and blank. 3/4 is a bottomless.
|--------static--------|
|static|----bottomless-------|
now my question is about the bottomless pane. The static pane at the top is targeted towards the bottom right pane.
Can I get that to be a redirect from a separate html file or must I write all the options out in div’s and make them visible? I’m so used to using frames, but I want to learn how to use CSS so I can take advantage of transparency and a more flexible layout.
thanks for your help
sparky
