I am trying to use the E-Product action with a Menu/List item but so far I not having much luck.When I apply the E-Product action to the Menu/List item what should I be entering in the Value. For example if I want a list of shirt sizes.
Create a menu/list of the possible variations eg size and colour and then apply the E product Variation action to that list.
Firstly create a table
38" T shirt-----Price-------Quantity Dropdown-------Colour selector dropdown
Apply the E-buy form action to the table 1cell X 4 col and specify price for the 38" shirt
Insert a menu/list item in the Quantity cell, populate it with your numbers ie. name:1 value: 1, name:2 value:2 etc and apply the E quantity action. Insert a menu/list item in the colour cell and define the values ie name:red, value:red - name:blue: value:blue etc apply the E product variation action to this menu/list item alternatively you can have a size selector name:38’ value:38’, name:40’ value 40’ etc.
The problem is that the variation of the product doing this is colour or size but the basic price remains the same.
If your 38’ shirt is a different price from your 36’ shirt then you will have to list them as different products eg 36’ shirt £18, 38’ shirt £20 with variations for quantity and colour.
