If you do in fact have the latest version you might try deleting the preference file “Freeway Pro 4 Preferences” in your user library/preferences and then try launching.
I have seen help with various problem with other apps.
I"m running leopard and have recently tried Freeway Pro and Freeway Express both 4 and 5 and they all launched fine.
Freeway is a step away from Iweb.
Iweb has it’s limitations, but if it suits your needs and don’t have the time to devote to the Freeway learning curve you might want to stick with it.
Freeway is hands down the easiest and most flexible webpage program next to Iweb without the Iweb limitations and associated problems.
This of course is my opinion, but believe me I’ve poked at them all (on the Mac side).
If you haven’t you might want to take a look at the Freeway tutorial movies.
If you do have a bit of time to get on to the basics I think the effort would be worth it.
Nice looking Iweb site, by the way.
It appear a couple of you pages have overlapping areas though.
It should not have taken a full weekend. At one point, after I had
learned more about the program, I decided to delete everything and
start over from scratch because I knew I could do it quickly. The
hardest part was using OTHER PROGRAMS to create the background image,
which FW effortlessly turned into wallpaper.
The web site has great tutorials. This forum is very patient with
absolute beginners.
