Does anyone know how to get full screen with slideshow pro in freeway? I followed the flash instructions correctly. It works locally on my computer but once I upload everything it no longer works? Here is the link, any help would be great for this work in progress site…
Basically you’d need to make sure it was published in Flash 9 format and then adjust the settings in the first step in Flash. Once outputted, drop it into Freeway. Select the SWF file and then goto ‘Item’ and select ‘Extended’ and then under “embed” set the name to “allowFullScreen” then set the value to “true”.
See if that works and get back to me because I’d be interested in knowing.
