The Graphic effects on html boxes are creating with png files. Is there any way to get the effect created as JPEG or gifs? (yes I could build with photoshop slices - just trying to save time Freeway style here)
Reason why; IE6 does not display the png effects.
Also: I note that IE8 RC1 at netrender does not display png’s also is you test a page with Moved
Is a fix needed for Freeway to display png’s in IE 8 RC1?
The png fix FW employs uses javascript and NetRenderer has js disabled
so it won’t appear correctly.
You could always write your own conditional stylesheet(s) for IE6 or 7
or 8 or 5.5 and specify alternate images to be used for that browser
so you have the best of both worlds. I don’t believe FW allows you to
edit the FW-generated IE6 (or 7) 'sheet (why, I dont know) but it’s
still possible to do in any case.
style here)
