Hello
I have a problem on my website, made with freeway.
High Def images appear Low Definition.
(I’ve load a 3Mega image, and in the webiste folder it’s 33k)
Since it’s a photography work, it’s a real problem. Does Freeway reduce
images definition by default? and how can I change this setting?
thank you very much for your help
francesca
francesca bonesio
18, rue rampal
75019 paris
t. +33 6 76 06 53 10
You can adjust the quality setting of each image individually using the Inspector palette. Alternatively, you can import images as Pass Throughs (there’s a checkbox in the Import dialog) so they don’t get optimized at all. Make sure they are the right size before you import them though, you can’t scale or crop pass throughs at all in Freeway.
I hope this helps,
On 18 Nov 2011, at 16:07, francesca bonesio wrote:
Hello
francesca
francesca bonesio
18, rue rampal
75019 paris
