Help! Carousel not working on PC browsers
Hi all
Need some help Fast!
I have placed a Carrousel on this home page
It works fine on Safari on Mac but not in any of the PC browsers.
Can anyone see something obvious
Thanks Trev
Just as a follow up - it’s not working on Firefox either on the Mac!
Works with FF 3.0.14 on my G5 iMac
Hi David
Thanks for your reply. Yes, I had just found the problem and uploaded when I got your ping! A couple of javascript files failed to upload. After a bit of searching I found them and all appears to be well now.
Was in a bit of a panic - thanks for looking and your fast reply.
Regards
Was that Javascript that the action should have dealt with? Strange!
Glad you are sorted though.
Hi Dave
My fault, I use Fetch to upload manually and missed the files. For some reason I have always done it this way and not used the Freeway Upload option.
I normally upload the files recently dated by just selecting view by date. Somehow the .js files were way down the list.
Perhaps I need a more reliable upload option where files needed don’t always show as updated by date alone.
Thanks again for your time.
option.
Hmm. Perhaps this might be a reason to start using Freeway’s upload
feature instead? :slight_smile:
(Seriously though, it is very easy to miss things. It makes a lot
of sense to let the software and computer do the dull stuff for you.)
k
Hi Keith
I’m going to make point to check out the upload feature - I believe it only uploads what is needed on each new publish.
You are quite right - we should make things easy if the feature is there.
Thanks for your time.
That’s right, it uploads anything that’s changed, and also deletes
anything that’s no longer required in the site. This also means that
you can stay out of the site folder and leave it entirely to Freeway
to manage. Life gets easy! :slight_smile:
k
Thanks Keith
I’m Sold!
