Help: Lightbox Not Working-Don't Know Why
I would appreciate it if someone could look at this page and tell me why lightbox is not working:
http://www.sherrysbears.com/store.html (only first two images are linked)
I have set lightbox up before, but only with WebYep, and it worked fine. Now I’m trying to use it on this page, and I have been over everything and cannot seem to find the problem. I have inserted the initial code before /HEAD, I have uploaded the scripts, made sure the path to the images is correct in the css file and in the lightbox.js file. But it’s just not working.
I looked in the code and I can’t see anything wrong. Of course, I’ve been looking at it for several hours now …
Well it is actually working - just not where you would expect it!
It is opening the images way down at the bottom of the page. Way down.
Some sort of positioning problem?
Like DeltaDave mentioned, it appears to actually be working on some levels.
A quick look at your source code shows that the libraries are being added at least twice. This could very well be the source of your troubles.
Additionally, I do not see any inclusion of the lightbox.css file, which would control the overlay and positioning of the effect. Thus, the browsers do not know ‘where to show’ or ‘how to style’ the effect.
Rectify these couple issues, and things should be sorted out for you. Keep in mind, there is an Action for the “Lightbox” effect at: (http://www.coastalrugs.com/Actions/misc.actions.html)[freeware action]. You will also need to apply the supporting libraries via another Action like: (http://actionsforge.com/actions/view/18-protaculous)[freeware]
Plug: If you want more control and not having to add script libraries via another Action, see: (http://www.coastalrugs.com/Actions/mootoolssuite.html)[commercial action]
