Help needed with my graphic layer!
First: I’m new here.
Second: I posted last night in ‘dynamo’ but i think that was the wrong place to try!
Third: My problem is my updated site:
http://www.tircurstudios.com
After last night I have uploaded it ‘warts and all’ so you can see my problem.
The home page tells it all really - i love the layout and the graphics are a recurring theme throughout the site but because they pop up over the scrolling layer, when they disappear any links I may make will not be active because the graphic is top layer.
I had the same problem in a different way with the composition page but got round it using an ‘iframe’ for my audio player. ( I tried the ‘carousel’ first but that just meant multiple audio players going all at the same time!)
I like the instant response of the graphic layer and am reluctant to go down a separate ‘gallery’ route - although I will if it solves my problem.
Does anyone know how to return a result where the scrolling layer is always the active one?
Richard
I have sent you an example which should let me know if it doesn’t
max
thanks max - sorted
max
Richard Martin
028 8225 2950
07595 941918
