Help needed !
hi all,
could someplease have a look at my site please which ive now uploaded !
all pages are good except the contact page as youll see
any help really welcomed as im tearing my hair out !
thanks
Terry
http://www.terrymcshane.co.uk/index.html
Can you tell us what exactly you’re adding via html markup, mentioned in your other thread.
The mail chimp code you’re adding is applying 75px top padding to the body element is that something you are copy/pasting across ?
Simon
hi simon
thats exactly it when im adding the chimp code its out of kilter as it was ! ill have a look at the htlm now
You’re looking for this;
		body{
			font:12px/14px 'Helvetica', Arial, sans-serif;
			margin:0;
			padding:75px 0 0 0;
			text-align:left;
			-webkit-text-size-adjust:none;
specifically the
 padding:75px 0 0 0;
simon,
many thanks for your help,
its helped for most of the problem,
ive just amended and uploaded, its now put the logo text on the left out and the spacing is still out but as said, a big difference,
many thanks
ill have another look tomorrow to see the offending code !
so all sorted thanks simon
heres my site
let me know if you have a moment what you think ?
cheers
####Technical:
Lots of items do have “fixed” heights (haven’t looked at the widths) causing problems naturally.
Remove all of them towards undefined heights (the height will be steered by its content.
####Outline:
Honestly not much content and information shared.
The index as the most important page in a project has not much valuable information.
I’d never create a page with multiple youtube videos. One is enough - and if one is interested in more - I’d preferably create a YouTube channel sharing the rest.
####Design:
Can’t judge. I’m not a designer.
